AXOD pressure check
Does any one know where the plugs are for the pressures test on The AXOD tranny. I would like to see if the pump is smoked before I go further with it because of the 10 hrs to play musical transmissions. You see I know that is a Taurus I can get to the pump/valve body with a little jacking and tinkering. I know the pump is working but I dont know how well.
And as long as we are at it, does any one have the Shift solenoid on/off condition table. On the 97 axod tranny wasn’t there a mod to the program plate gasket to prevent erosion from plugging up the solenoid? If that is true,,,, you think that I could just change the solenoid and not have it get plugged up again? (thinking the gasket is already gone)
This is the problem; Car came in running just fine with 139k. Problem was at WOT starts in any range the darn thing would jump in and out of first gear (low pressure) Changed fluid and filter and the darn thing worked perfect for three days and about 100 miles. Now the darn thing will not go into first unless you back up a little then quickly go into first. First idea that came to mind was a problem with the range selection ckt. Because it acts just like a Ford does with an open. Nope!
Checked electrical and mechanical function of the shift solenoids, all at 20 ohms and making a nice clicking when turned on. Pressure control solenoid is working. SO I guess that I am stuck with either; bad solenoid CKT or computer (not likely) bad pump, plugged solenoid, or broken 1sr/revers servo. I am going to test the electrical signals to the tranny in a couple of hrs and was just hopping for the pressure test point by the time I am don doing that. But without the on/off table, it won’t tell me much.
Last but not least, cash is a big concern on this one, so I don’t think that they will go with a re-build besides the wiring harness being different (changing it will not be a problem) Wont any 96-99 AXOD work. Like I said changing the temp sensor etc is not a problem
