Vacuum Leakbbaker1985 05-20-2009, 11:15 AM I was changing my LIM and I noticed that I had a Vacuum Hose off, does anyone know where this goes? Here is a pic. http://i275.photobucket.com/albums/jj300/megybeth831/103_0983.jpg bbaker1985 05-20-2009, 11:16 AM Also dos anyone know the torque specs for the LIM? richtazz 05-20-2009, 03:25 PM what year is your car, and what motor (the valve cover looks like a 3800, but I'd rather be sure)? bbaker1985 05-20-2009, 07:19 PM 2000 gp gtp 3800 series 2 if do you know the belt routing on that tblake 05-20-2009, 08:22 PM there is no vacuum hose that goes to that spot. All GTP's have that same deal. Except its supposed to have sort of a spongy filter type of material over the top of it. It looks like yours tore off like mine is starting to. (refir to my thread with pictures) Click here (http://www.automotiveforums.com/vbulletin/showthread.php?t=951642) bbaker1985 05-20-2009, 10:09 PM Got my LIM gaskets change. The worst part was cleaning everything, every rubber vacuum hose on it was bad.But the GTP is running better than ever before thanks to ZZP! What is the factory boost set at, does anyone know. Because I hooked up a boost gauge today and it made 9 PSI. Car is 100% stock except for magnaflow mufflers tblake 05-20-2009, 10:14 PM 9psi seems a little high for stock, but might be ok. doctorhrdware 05-20-2009, 11:19 PM I wonder if you could use foam rubber on that. bbaker1985 05-21-2009, 11:40 AM ill make something for it civics have a little filter like that on map sensor and i think i might have one ive built two turbo civics the supercharger on my gp is makeing noise so i think i might turbo it Automotive Network, Inc., Copyright ©2012
