Originally Posted by cnoel626
I've changed the fuel pump, fuel filter, ingintion module, ingintion coil. And still my car will run for a little bit but as sone as hit the gas it dies and won't start until I let it sit for a while.
what testing have you done,,,,? or just replace parts ???
do you own a volt ohm meter,,,pressure gauge ?
how did this issue come about///any work done/accident damage etc...?
did the distributor cap get wet ///did you check for spark ???
also DTC may,,,,,may,,,,help to locate problem.....
possible its the security issues as well...
