Originally Posted by tacmale
I have heard so much bad about the 2.8
Most of the negative comments about the 2.8 are nonsense. It is an very reliable, long-lived engine. Your own vehicle is proof of that.
The biggest 'problem' with the engine is that most of them are a little underpowered.
Since 1980, GM has made both 110 and 135 HP (later 140 hp) versions, in both FWD and RWD configurations.
The vast majority made were the 110 version, and often, this engine simply did not have the beans to power anything other than a J-car (Cavalier) with much authority.
IMO the 135 version should have been the only one made. It was much better, yet got about the same gas mileage and was no more expensive to make.
Unfortunately, the 135 version was only available in the Citation X-11, Camaro/Firebird and the Fiero.
In fact, the lack of decent power lead to a problem in pre-1985 engines. People had a tendency to rev these engines regularly past 5000 RPM in an attempt to get more power. They would eventually spin bearings (often the #5 rod bearing) due to excess revs.
GM added larger bearings in mid-1985 to correct the problem. IMO if they had used the 135 version there may not have been a problem in the first place.
