Re: 96 Park Avenue abs & traction control
Start with the fuses first, then goes from there. A lot of times on old girls, a visual check will find things like a bad bearing has chewed the sensor, a plug is off/dirty etc. The traction control points toward the front of the car.
On the early cars they turn on and off the front brake on the wheel that is spinning in snow ice, or mud. So I would just look very close for bad wires, bad sensors and bad plugs. after that it is matter of taking a lot of time and checking with appropriate electronic gear, or. Take the thing to some one with an ABS scanner and take a look. They are about 175$ to 500$ at auto part stores or "things" like mack, snap on, or napa
