Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Ford > Explorer/Explorer Sport Trac
Old 05-18-2009, 09:30 PM   #1
MPraz
MPraz Normal reputation
96 Explorer Interior Lights Won't Go Off !
Hello,
I see this is a common problem, they sometimes will go off, by slamming the door. At times, I have to pull the fuse while driving, but then you lose the control of the windows. If I pull the bulbs themselves, will the outlets, still draw power from the battery? Would hate to find this out, and drain the battery.
Thanks
MPraz is offline   Reply With Quote
Old 05-18-2009, 11:13 PM   #2
shorod
Taurus Guy
shorod's Avatar
shorod Normal reputation
Re: 96 Explorer Interior Lights Won't Go Off !
If the only draw is from the bulbs, pulling them will eliminate the current draw. Pulling the bulbs will open that portion of the circuit, therefore there will be no current flow/drain.
Before you go to the work of pulling the bulbs, make sure that the instrumentation light dimmer dial at the headlight switch is not rotated to the "Interior light" position.
If you find the dimmer is not the issue, it may be easier to clean the door pin switches than to pull the bulbs and this may fix the issue. If not, then you're probably looking at a broken wire in the door connector cluster.
-Rod
shorod is offline   Reply With Quote
Old 11-20-2009, 01:09 PM   #3
cntrchfrk
cntrchfrk Normal reputation
I know its an old thread- but i had the same problem. Rear hatch sensor was bad and the car thought it was still open- my door ajar light would stay lit. The vehicle has an override sensor that when you drive a small distance, the light will auto shutoff. If that didnt happen, its probably what rod said, or a bad interior light switch
cntrchfrk is offline   Reply With Quote
Bookmarks
Google
Web AF
