anti brake light on ?
texasplaya
05-18-2009, 07:44 PM
i got a 2000 buick regal my anti brake has came on like 2 days ago what can it be and i think i see a little bit of fluid coming from around the master cylinder can that be it to dont know need help try to get inspection done ?:runaround:
GTP Dad
05-18-2009, 07:52 PM
The antilock system performs a self diagnostic each time you start the car. Since the light remains on it has found a problem. I would believe that you have a bad abs sensor. You will need to have the car scanned with an abs capable scanner to find out. If the sensor is bad the entire hub assembly will need to be replaced as the sensor and bearing are a single unit.
texasplaya
05-18-2009, 10:21 PM
i got the right front hub replaced already so it has to be the sensor
GTP Dad
05-19-2009, 08:23 PM
The problem may be the hub on the opposite side. The right one went out on my GTP and when we scanned it the left one was bad too.
