Originally Posted by rebelvance
Thanks for the reply.I did an ohm reading on the wheel sensors and this is what i got; LF:0 ohms, RF:1736 ohms, LR:2154 ohms, RR:2138ohms. I think it would be safe to say that the left front is the problem. I'll get a new one tommorrow from GM. I'm curious as to what the new one will read? Any way, Thanks for confirming what i suspected.
WHERE did you connect the ohmmeter? At the sensor; or in the wiring harness somewhere?
When my '92 had the ABS light on, the harness itself was the problem--the sensor was OK, but one of the two wires was broken very close to the sensor connector.
I had to splice in a $24 harness section to fix the problem.
