Engine rattling and loosing powerRebelRooster 05-17-2009, 08:42 AM My 92 Stanza has started rattling recently. I thought it was the valves needing adjusted (I am not a mechanic). On my way to work a couple of days ago it just started loosing power, it would sort of quit and pick back up again. If you tried to give it fuel it would bog out. Then it would pick up and run correctly for a while, then cut out again, it got so bad it wouldn't hardly pull it's self. I nursed it into the local garage and they checked it out for me. They say I need a new timing chain and oil pump. Normally I wouldn't question their judgement, however the mechanic told me that he adjusted the timing and the car ran well and quit making the noise, then when he went to take it out for a second test drive the problem was back. My question is could the distributor have an effect on the timing chain and noise? I drove the car home last night to store it until I can afford the repair ($900) and it seemed to run much better. It still cut out occasionally but made it home without a problem. Does anyone have any thoughts or has anyone had a similar problem in the past? Any help would be appreciated. Tom abe151ely 06-25-2009, 02:07 PM I'm having just about the same problem with my 92'. I took it to the mechanic and he told me it was the camshaft and valves. there is also a ticking noise(which he said was the valves)when its in park or idle it surges really bd and almost wants to die.as for he knocking it happens when I accelerate and when I'm climbing hills. the car is still drivable but doesn't have much power and it sounds like sh**. I am looking for a new cam and I will most likely have it replaced in the next month. Any one else have a clue? feel free to e-mail me or hit me on yahoo instant messenger. aely@prodigy.net vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
