camber questionjam4484 03-31-2003, 09:07 AM I plan on lowering my civic lx on neuspeed sofsports. They lower the car 3/4 of an inch. If I drop it that little will I stil need to get a camber kit for every wheel? And also do you think kyb gr2's would be good enough for that drop or no? If no what should I get that is still low in price but better than the gr2's? CivicSiRacer 03-31-2003, 09:34 AM YOu really only need a camber kit if you drop more than 2". jam4484 03-31-2003, 12:01 PM Originally posted by CivicSiRacer YOu really only need a camber kit if you drop more than 2". Thanx a lot...but will my tires wear unevenly at or only if it is lower than 2 inches? CivicSiRacer 03-31-2003, 03:17 PM I believe toe angles wear out tires quicker than camber. As long as you get your toe within spec you should be fine. jam4484 03-31-2003, 03:22 PM Originally posted by CivicSiRacer I believe toe angles wear out tires quicker than camber. As long as you get your toe within spec you should be fine. So as long as I get my tires aligned after I get the springs on I should be set? hondaman-iac 03-31-2003, 04:52 PM why bother with a 3/4" drop ? and to answer your question no you won't need a camber kit. make sure your toe and the caster are set thou, or it will handle like crap jam4484 03-31-2003, 07:50 PM Originally posted by hondaman-iac why bother with a 3/4" drop ? and to answer your question no you won't need a camber kit. make sure your toe and the caster are set thou, or it will handle like crap The reason why I am going with a 3/4''is becasue I live in ct and in the winter I wont be able to drive a slammed car. I know I can get coilovers I just want to get the sofsports becaus ethey say they are just as good as the sport springs they just don't lower the car as much. Automotive Network, Inc., Copyright ©2012
