Is the chamber adjustable on a '96Lbert 05-16-2009, 06:22 PM I took my van for an alignment. I was told the chamber is not adjustable. Is this true? wiswind 05-17-2009, 09:01 AM It is partially true. There is a camber adjustment kit......a plate that is installed on the top of the strut assembly....which permits the camber to be adjusted in 1/4 degree increments. Installation of this kit would require that the strut assemblies be removed to and re-installed with this new top plate. The camber should only need to be adjusted if the vehicle has been damaged, such as in a accident. So, unless something happened to make a significant change in camber, it is not something to worry about. Lbert 05-17-2009, 08:25 PM Wiswind, thank you! Automotive Network, Inc., Copyright ©2012
