please help!
wade623
05-16-2009, 11:06 AM
i was checking the coolant because i put in a new radiator and i found oil in the coolant i dont know if it is oil or transmissoin fluid but it did not do this before the new radiator so im thinking it could be the radiator or could it be something else:banghead::banghead::banghead::banghead::bangh ead::banghead::banghead::banghead:
CL8
05-16-2009, 11:56 AM
blown head gasket or cracked engine block?
wade623
05-16-2009, 12:04 PM
like i said it did not do it before i put a new radiator in it and there is no water in the oil
wade623
05-16-2009, 12:19 PM
no cel an it only has 79k on it
93pb
05-16-2009, 05:05 PM
Could be the tranny coil in the radiator is leaking. If you have an air compressor and can remove the tranny lines from the radiator, do so and put compressed air to the fittings and see if you get air bubbles from the radiator . If you do then the coil is leaking into the coolant.
wade623
05-17-2009, 04:21 AM
im actually hoping it is that is there any way to tell if it is oil or transmission fluid in the coolant before i start taking it apart?
BNaylor
05-17-2009, 09:04 AM
What year Aurora is this and which engine?
wade623
05-17-2009, 09:19 AM
1999 4.0 northstar
i just replaced the radiator thats why i think it that but if its something else i dont know hat im going to do
:runaround:
wrenchboss26
05-17-2009, 03:30 PM
did you ever put any kind of stop leak in the old radiator? some brands can make the fluid milky. of course a blown headgasket can let compression get in the cooling system, and cause a radiator leak. why did you replace the radiator?
wade623
05-18-2009, 10:30 AM
because the plastic was cracked and it is brown not milky
maxwedge
05-18-2009, 02:11 PM
Dexcool can wind up in that condition also if allowed to mix with air for too long, not uncommon.
wade623
05-19-2009, 05:31 PM
that is what it looked like when i took it out yesterday
http://i103.photobucket.com/albums/m148/wadedark/DSC01011.jpg
wrenchboss26
05-23-2009, 10:15 AM
that looks like tired wore out dexcool
wade623
05-23-2009, 07:23 PM
it was only a month old i put new stuff i and well see what happens
wade623
05-24-2009, 07:04 PM
ithink i found the problem the cap went bad:rolleyes:
wade623
05-30-2009, 05:12 AM
i think the cap was bad for some reason
