Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Lumina
Old 05-14-2009, 05:49 PM   #1
gw84
gw84's Avatar
gw84 Normal reputation
Send a message via MSN to gw84
93 running rough!
93 3.1L. I've had a CEL on for awhile now showing codes 32 and 43 I don't know if that has anything to do with my problem tho. Recently after some harsh wind and rain (like 100+ mph) I went out to move the car and it started and acted like it was going to die, then after that nearly every time I start it, the car shakes and doesn't really even out too well. I take off and it continues to shake with a noticeable lack of power until it shifts to 2nd, then it seems to really take off. not sure what to check.
This ain't your grandma's car!!
gw84 is offline   Reply With Quote
Old 05-15-2009, 01:54 AM   #2
Bearwulf
Bearwulf's Avatar
Bearwulf Normal reputation
Re: 93 running rough!
Check all connections from knock sensor to ECM including grounds. If necessary, have MEMCAL/PROM checked. Which trans does it have?
Bearwulf, the "howling Grizzly" of the north.
90-Eurosport
91-2 dr. euro body-220k got t-boned
91-4 dr. " "
93Eurosport
GRANDPARENTS RULE!!!!!!!!!
Bearwulf is offline   Reply With Quote
Old 05-18-2009, 12:01 PM   #3
gw84
gw84's Avatar
i believe it has the 4t60e trans
Old 05-20-2009, 01:25 AM   #4
Bearwulf
Bearwulf's Avatar
Possibly bad shift accumulator low range on 4t60e trans. Possible bad connection or short in knock sensor cir. Code 43 Knock sen. cir. controls amount of fuel injected by shortening or lengthening the time the injectors open.
90-Eurosport
91-4 dr. " "
93Eurosport
Old 05-20-2009, 12:09 PM   #5
gw84
gw84's Avatar
i'm hoping it's just a knock sensor...although both codes were present before the conditions started. I wonder if the trouble happening right after bad weather is just a coincidence...
Bookmarks
Google
Web AF
