Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Cavalier > Cavalier Problem Diagnosis
Old 05-14-2009, 02:40 PM   #1
we-r-Tokarz
we-r-Tokarz Normal reputation
97 Cavalier 3T40 transaxle drain, fill plugs
does the final drive have any drain or fill plugs?
When I recently changed half shafts no oil came out and yet there is a seal I trust this forum to know....thanks
we-r-Tokarz is offline   Reply With Quote
Old 05-14-2009, 04:03 PM   #2
J-Ri
J-Ri's Avatar
J-Ri Normal reputation
Re: 97 Cavalier 3T40 transaxle drain, fill plugs
The differential and trans are one and share the same fluid. If you've got a trans dipstick (some do, some don't; and I can't tell you which number has what with 100% confidence), just check it hot while idling in park. Trans full=differential full. If there's not a dipstick, there's a "check plug" in the passenger side of the transaxle (10 or 11 mm plug a few inches up from the pan on the part that sticks out). You have to drive the car to get it hot, put the whole car up on jack stands (has to be level), shift through all the gears and then back to park, and then remove the plug. If you've never done this before, I'd remove the plug and let fluid run out until it slows to a trickle just incase it is overfilled. If no fluid comes out, there's a red vent/fill plug under the air filter box, add fluid there until it runs out the check plug.
Depending on the angle of the vehicle when the halfshaft is removed, sometimes you don't get fluid out even when the level is full.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
When you buy something... a bottle of pop for example, who gets the profit from it and what do they do with it? Maybe your money's going to groups that want to hurt you. I think everyone should do a search for things they purchase regularly "____ supports". Might just find a company you won't buy stuff from anymore.
J-Ri is online now   Reply With Quote
Bookmarks
Google
Web AF
