Re: Speedometer incorrect - 98 tahoe
GPS is a good way to measure speed. The best way is to go by mileage (or in your case Km) markers on the highway. At an actual speed of 60Km/hr it takes 60 seconds per Km. Adjust your speed to achieve the 60 seconds per Km and record what the speedo is reading.
I agree with checking the tire sizes as to OEM. Could the gear ratio's have been changed in the past? The 40Km/hr difference indicates a much lower gear ratio (higher numerically, such as, 3:42 down to 4:11).
In answer to your question as to how to correct this. The only way I know of is to take it to a good repair shop that can re-calibrate the VCM to what gear ratio and tire size you have. By tire size I mean the height of the tire. Once they get it close it may take a couple of VCM adjustments to get it right.
"R57 3CAR" 210 2dr post. 420HP 355 F/I 4sp 3:42 posi. (Dale Earnhardt tribute done by me.)
75 GMC Vandura 3/4 Ton
78 Chevy K5 Blazer
98 Chevy K2500 Suburban LT/7.4
05 Dodge Ram 3500/Cummins (Wifes horse hauler)
