Re: 1996 2.2 heater
99% of the time it's the blower motor resistor, rarely the switch can go bad and not give power to the resistor below/above a certain level. Check that you have voltage to the resistor on all the wires (except the ground), if you do, the resistor is bad.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
When you buy something... a bottle of pop for example, who gets the profit from it and what do they do with it? Maybe your money's going to groups that want to hurt you. I think everyone should do a search for things they purchase regularly "____ supports". Might just find a company you won't buy stuff from anymore.
