Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Buick > Regal
Old 05-12-2009, 09:19 PM   #1
alabamatx
alabamatx Normal reputation
Brake Light Problem
I'm trying to solve a bit of a mystery about a brake light problem on my '98 GS.
The right rear brake light won't come on when the brake is applied. The bulb & socket are OK, so I tried a shortcut by using a jumper from the left light.
That fixed the brake light issue, but then when the brake was applied while using the right turn signal, the turn signal would freeze on and not flash.
Furthermore, the applying the right turn signal would cancel the cruise control.
I removed the jumper and the right flasher & cruise control are back to normal but no right rear brake light.
Can anyone suggest a way to troubleshoot the brake light problem?
alabamatx is offline   Reply With Quote
Old 05-13-2009, 10:26 PM   #2
BNaylor
BNaylor's Avatar
BNaylor +50
Re: Brake Light Problem
What ever fix you are applying is affecting the turn signal flasher. Based on your symptoms it sounds like a bad multifunction and hazard switch (stalk) problem or even the ignition switch.
'08 Pontiac Grand Prix GXP (Liquid Silver Metallic) - LS4 5.3L V8
'97 Pontiac Grand Prix GTP - L67 Series II 3800 V6 Supercharged
Timeslip 08/12/06
AF Community Guidelines
BNaylor is offline   Reply With Quote
Old 05-14-2009, 01:49 PM   #3
alabamatx
Thanks for the response BNaylor.
When I tried the jumper wire and it affected the cruise & flasher, I started to suspect the multifunction switch, but since it works fine so long as I just don't have a right side brake light, I have to believe the brake light problem is something else (hopefully).
The multifunction switch is fairly new. The original crapped out a year or so ago.
I can't quite figure out how the brake lights are activated. There must be a switch or sensor somewhere. Does the multifunction switch control the brake light? Do the three brake lights get power from a common source? Since two work and the other one doesn't, could it be a bad harness connector to that light?
Old 05-14-2009, 10:17 PM   #4
stripe
stripe Normal reputation
I re-wired mine off the center brake-light.
In the end it was the switch and the connector in the turn signal.
Cheers
Stripe
stripe is offline   Reply With Quote
Old 05-15-2009, 12:03 AM   #5
BNaylor
BNaylor's Avatar
BNaylor +50
It might help to reference wiring diagrams like out of the factory service manual. The regular brake lamp circuits pass through the multifunction switch via the hazard switch portion. The third brake light does not.
Timeslip 08/12/06
Old 05-15-2009, 06:53 PM   #6
michtom
michtom Normal reputation
Your suspicions are more than likely right. Sounds like the multifunction switch is bad again.
michtom is offline   Reply With Quote
Bookmarks
Google
Web AF
