Has anyone installed aftermarket radio themselves?CrapaTaurusWrecks 05-11-2009, 02:16 AM I want to upgrade my stock am/fm radio in my 1995 Escort LX wagon. I want to know if there's something out there that will snap in with no modifications of the dash or wires? I am pretty handy and have the radio removal tool. ricebike 05-11-2009, 07:46 AM http://cgi.ebay.com/FORD-ESCORT-86--1996-RADIO-INSTALL-KIT-+-WIRING-HARNESS_W0QQitemZ350161253477QQcmdZViewItemQQimsxZ 20090202?IMSfp=TL090202128009r33049 those kits are complete for your vehicle; comes w/ a wiring kit so you just solder the plug to the aftermarket single-DIN unit & plug into your OEM harness... http://www.installdr.com/InstallDocs/FLM/Escort.html here's a pdf format just in case your wiring diagrams in that kit didn't come w/ it... chrisanthony 05-12-2009, 11:06 AM http://cgi.ebay.com/FORD-ESCORT-86--1996-RADIO-INSTALL-KIT-+-WIRING-HARNESS_W0QQitemZ350161253477QQcmdZViewItemQQimsxZ 20090202?IMSfp=TL090202128009r33049 those kits are complete for your vehicle; comes w/ a wiring kit so you just solder the plug to the aftermarket single-DIN unit & plug into your OEM harness... http://www.installdr.com/InstallDocs/FLM/Escort.html here's a pdf format just in case your wiring diagrams in that kit didn't come w/ it... Hi I installed a aftermarket sony deck in my car with a 12 cd changer. There is no need to solder wires together. You might have to buy a extra wire harness that’s about 15 bucks (FORD Premium Stereo Harness). This lets you link up the premium stereo wires and power connector in the escort to the corresponding wires to the aftermarket stereo. Its very simple. As you take out the stock stereo you well see to studs in front that well block any other stereo from going in. Since its plastic I just filed it down and now I’m enjoying an aftermarket deck. J Anther good idea is to replace the stock speakers, cuz you would not get the full effect from the new deck with those. ricebike 05-12-2009, 02:29 PM You might have to buy a extra wire harness that’s about 15 bucks (FORD Premium Stereo Harness). This lets you link up the premium stereo wires and power connector in the escort to the corresponding wires to the aftermarket stereo. yes, that's what i meant... w/ that kit, it comes w/ the extra wire harness/ plug that you have to either crimp or solder to it.... then plug the aftermarket unit directly into the OEM factory harness... but, chris, you don't need those plastic adaptors to make it flush to the console? if not, OP, then just go and buy the plug then... chrisanthony 05-12-2009, 04:26 PM yes, that's what i meant... w/ that kit, it comes w/ the extra wire harness/ plug that you have to either crimp or solder to it.... then plug the aftermarket unit directly into the OEM factory harness... but, chris, you don't need those plastic adaptors to make it flush to the console? if not, OP, then just go and buy the plug then... hi..it depends on the deck..for me it was very hard to find a piece that would make my deck flush with the console..so i just use the plastic trim that came with the deck...usually thats enough.... toddman67 05-12-2009, 04:48 PM Go to www.crutchfield.com (http://www.crutchfield.com) they will have a listing of the equipment that will work in your car. They will also set you up with a direct connect wiring harness that will connect to the existing OEM harness. Give them a call. chrisanthony 05-14-2009, 09:17 AM Hi OP How's the installation of the radio going? Automotive Network, Inc., Copyright ©2012
