Re: 96' tahoe signal trouble!
Sounds like a bad multifunction switch. I can't remember what year they went to the connector being at the switch, but if yours has the old style where it's under the dash you could unplug it and see if it still does it. If it does, there's a short to voltage on the headlight wires. If it doesn't do it, then I'd say, 90% sure, that it's a bad multifunction switch.
If you've got a trailer connector on it, make sure the tail light terminal isn't bent and touching the left turn/brake terminal.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
So I go to this get-together at a friends house, not remembering it's a few days before Halloween. I see a bunch of dirty looking strangers. Then I see a guy that was clearly wearing a Halloween costume and I make the connection, and say "Oh yeah, Halloween... y'all goin' as a group of bums?". Turns out they weren't wearing costumes.
