Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Dodge > Nonspecific
Old 05-08-2009, 01:59 PM   #1
kcrp
kcrp Normal reputation
97 caravan a/c problem
i have a 97 caravan with a 3.3 engine. the a/c has become intermittent. it will blow cold for several days or weeks and then it starts blowing warm air. after a day or so it starts blowing cold again. i have checked the compressor/ clutch when it's blowing hot and it's not turning. i can turn the clutch freely by hand when engine is off. compressor and clutch run smoothly (no noise). i have checked the refrigerant levels,they are good. checked fuse and relay,both good. was told to check low pressure switch. can someone tell me where it is located and how to check it? also, any other ideas on what else i might need to check? thanks
kcrp is offline   Reply With Quote
Old 05-08-2009, 02:27 PM   #2
jpb53
jpb53 Normal reputation
Re: 97 caravan a/c problem
This system does not have a low pressure cut-out switch. It has a pressure transducer. This link will tell you how it works.
http://www.automotiveforums.com/vbul...d.php?t=909708. Also in the future you might have better luck posting in the Caravan/Voyager specific forum.
jpb53 is offline   Reply With Quote
Old 05-08-2009, 04:20 PM   #3
kcrp
Thanks for the info. could you please tell me where the pressure transducer is located on my van?
Old 05-08-2009, 08:48 PM   #4
jpb53
It's mounted to the high pressure line which is from the compressor to the condenser. IIRC it is behind the passenger headlight area in the eng compartment.
Bookmarks
Google
Web AF
