77 caprice trying to turn itself over after shutting off
Dacaprice
05-07-2009, 11:19 PM
hi this is for my friends 77 coupe. When he shuts the car off it will sound like its shutting down normal then all of a sudden it wants to turn itself over a couple more times then it will finally shut off for good. any help?
silicon212
05-07-2009, 11:25 PM
That's called 'dieseling' and occurs due to any number of reasons, including but not limited to -
Overheating or plain running hot
Low quality gasoline
Fast idle
Vacuum leak
Incorrect ignition timing
Burned valves
Carbon buildup anywhere in combustion chamber
j cAT
05-08-2009, 11:01 AM
Fast idle
Vacuum leak
Burned valves
you forgot to mention the anti dieseling solenoid....
this and the carb not adjusted correctly..
I have seen this solenoid bind up then the throttle plates stay open...
coupeboy
05-11-2009, 09:00 PM
the carb culd need rebuilding or its running too hot antifreeze not flowing rite or not enuff
