Air Cond Recharge: Gauge not reading pressure-Do I need a special fitting, or what ?Panchoz3 05-07-2009, 01:19 PM Air Cond Recharge: Gauge not reading pressure-Do I need a special fitting, or what ? My A/C is cooling, but wanted to see if it needs to be topped off. Hooked up gauge to low pressure line on 2000 430CLK. Gauge is not reading any pressure. Tested/connected gauge on 1997 BMW Z3. Gauge does not read pressure. Tested/connected gauge to 1993 Jeep ZJ. Gauge reads good pressure. Gauge reads pressure on American, but NOT on German cars. So, is this a German thing? Do I need some special fitting, or what? Thanks Note: All cars, CLK, Z3, are blowing cold air--have good a/c units. eclass 05-12-2009, 04:50 PM 93 jeep = R12 all others = r134a the fittings are different. Panchoz3 05-13-2009, 11:08 PM 93 jeep = R12 all others = r134a the fittings are different. You are very wrong. 1993 ZJ, purchased new in May 1992 (30 days after into to market) See link: http://www.panchogun.com/FVWebPhotos/FV-Cars-ZJ-R134.jpg eclass 05-15-2009, 09:00 AM On the clk, with key on- set temp. controls to 72 on left and right, press the REST button and hold it for more than 6 seconds. When the display changes press the left auto button to change the number shown on the left. Press until the number 7 is displayed on the left- the number shown on the right will be your system pressure in BAR on the high side. As long as the sensor is working correctly this is your pressure, with that said.. are you hooking up the the low side or the high side with your gauge? They are different in size. Components location for A/C system Figure 1 A High pressure connection B Low pressure connection (engine 112) B12 Refrigerant pressure sensor B12/1 Refrigerant temperature sensor 1 A/C compressor 2 High pressure line 3 Condenser 4 Low pressure line 5 Receiver/dryer 6 Suction line 7 Low pressure line to evaporator 8 Expansion valve 9 Evaporator http://www.startekinfo.com/manual/volumes/cc/3_10/41_1.gif Automotive Network, Inc., Copyright ©2012
