Hi all
I've been hanging round this site for a while but thought its probably about time I contributed. I've been working on a Fujimi Nissan Fairlady 300ZX for about the last month or so.
I should mention that I newly back into the hobby after a break of a number of years. In the past I knew nothing of things like removing mold lines, using primer and even using an airbrush having never owned one. I had also never altered a model in any way. This kit and what I've seen online has changed all that.
Firstly, this kit had a few faults, main one being some damage to the rear pillars, both were pushed in and deformed a bit.
I have sorted that with a bit of styrene glued inside the pillar and sanded down a bit to allow the window to still fit.
Next was the seats, I didn't like the hollow backs and so filled them in with some styrene, putty and a few coats of Mr Surfacer. Heres a before and after shot.
And the last main problem was a test fit of body and interior revealing a rather large gap.
Once again I used styrene to sort this out and although I don't have a pic to back it up, the results were very satisfying.
Using my new airbrush I sprayed the spare whell housing and sump on the chassis Gunze silver followed by a mostly successful masking and spraying of flat black. Only a small amount of touch up was required around the silver. This was followed up with my very first attempt at dry brushing.
I then moved to the interior. I used a custom mix of paint to get a tanish colour for the upholstery and a light grey colour as a contrast. I'm hoping to flock the interior too, something else I've never done.
The black parts have been lightly dry brushed too in an attempt to bring out some detail.
And finally I got to the body. I know most people start with the body but for me it was the part of the build I was most nervious about so I kept putting it off. I can now see the benefits of doing it first though, takes awhile for coats to dry and set allowing the next steps to happen.
Still have a way to go, next up is learning how to polish the body. I have a few things to try out there.
Well, thats where I'm at. I'll hopefully post more when I get more done in the meantime I'm keen to get any comments and suggestions anyone is willing to share.
Thanks
