Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Monte Carlo
Old 05-06-2009, 08:38 PM   #1
kyle90316
kyle90316 Normal reputation
1996 Monte Carlo, Turn Signals not working yet Hazards are
Turn signals were working fine, had to turn on hazards, now the turn signals will not work but if i switch the hazards on they work fine. I thought I blew a fuse but I can not even locate the turn signal fuse.
Could anyone help,
Thanks
kyle90316 is offline   Reply With Quote
Old 05-08-2009, 03:27 PM   #2
3CXOD
3CXOD Normal reputation
Re: 1996 Monte Carlo, Turn Signals not working yet Hazards are
Well.. It might be battery related or wiring related.
Most likely wiring relation tho. Maybe a short.
As Turn signals have nothing to do with your 4-ways.
4-ways are made to work even if your vehicle is turned off as Turn signals aren't.
Just thought that was an interesting tidbit.
3CXOD is offline   Reply With Quote
Old 05-09-2009, 12:07 AM   #3
MagicRat
Might-T-Bird
MagicRat's Avatar
MagicRat +50
Take a look at your owners manual to find the fuse panel. The most common causes for a malfunction are a blown fuse and/or the turn signal flasher unit.
If it blows another fuse, check out the turn signal light bulbs. A defective bulb or socket is the most likely source for an electrical short.
"We' re all here because we're not quite all there."
Human Evolution in 10 easy steps:
Get out of tree....... Stand Tall....... Walk around the savanna.......Grow big brain....... Shed fur.......Flee animals....... Make tools.......Chase animals....... Make fire....... Invent politics.
MagicRat is offline   Reply With Quote
Old 05-09-2009, 12:54 PM   #4
crash935
crash935 Normal reputation
Turn signals, 4 ways and brake lights all go through the turn signal switch which is buried on the turn column. if its not a fuse or relay then its more than likely the turn signal switch.
crash935 is offline   Reply With Quote
Old 05-16-2009, 09:40 AM   #5
Blue Bowtie
Registered Offender
Blue Bowtie's Avatar
Blue Bowtie Normal reputation
It's very likely you'll be doing this soon:
Blue Bowtie is offline   Reply With Quote
Old 05-16-2009, 01:57 PM   #6
toddman67
toddman67 Normal reputation
Check #30 fuse 10amp for turn signals.
toddman67 is offline   Reply With Quote
Old 07-24-2009, 03:00 AM   #7
noimaD
noimaD's Avatar
noimaD Normal reputation
If you can gently pull the high beam switch to you but not turn the highs on ,,,,and the brake lights and turn signal work correctly then it is a turn signal switch prob in the column as quoted by ,,,Blue BowTie
noimaD is offline   Reply With Quote
Old 08-13-2009, 06:08 AM   #8
candic80
candic80 Normal reputation
My car hazard lights came on after taking my car into a mechanic to fix the cad converter. The mechanics couldnt figure out why they came on and it wont shut off (the switch is broke) so they took the whole plug out from under my dash and now my turning signals dont work. however, when I drove my car home and shut off car, the flashers started flashing again and now the flashers wont shut off.. and now my car wont start.Im furious and feel I shouldnt have to pay the mechanic the rest of the money i owe until this problem is resolved since I didnt have this problem before! Any suggestions as to why my car is doing this?
candic80 is offline   Reply With Quote
Old 08-28-2009, 01:48 AM   #9
noimaD
noimaD's Avatar
Is your car equipped with an aftermarket security system ?
Bookmarks
Google
Web AF
