Battery Drain through Maxi Fuse
I have a 1995 Buick Park Ave.Battery going dead when setting over nite.used a test lite between neg.side of battery and ground cable,showing current draw.Started pulling outside maxi-fuses first,come up on 60-amp.fuse labeled pwr. door locks,trunk release,the horns where already unhooked.when i pulled the fuse,test lite would go out.(except for being real dim)Have unhooked the trunk release.Have`nt got to unhooking pwr.door locks yet.Hope its the door locks.Lite is still real dim untill i pull the elc maxi(electronic level control)Is there ever been some trouble with the wires coming out of the car to the door?(inside the rubber cover)All fuses in,when i plug a horn in it will beep with out touching horn button.any ideas on this mess? I went through BATTERY DRAIN threads with no luck.THANKS, DAN H p.s. pulled little fuses behind glove box(fuses 1,2,3)
