Re: 2002 astro hard to start after warm-up… ecm???
Glad you figured it out and got her going again.
Dirty/worn terminals in the distributor cap is a common observation. However, what causes most of it is perfectly normal. When replacing the cap & rotor, a small amount of silicone dielectric grease is applied to each terminal, inside and out. When the engine is running, the current that passes through the grease crystalizes on the terminals inside the cap, perfectly normal. A problem that is often overlooked with the distributor is a clogged vent screen in the bottom of the housing. The vent is there to reduce condensation buildup on the underside of the distributor cap. Excess condensation can cause hard starting, no start, misfire, and can also set P0300 series DTC's, (Diagnostic Trouble Codes). GM addressed the issue by instructing the technician to remove the screen. Just something to keep in mind.
