Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Volkswagen > Jetta/Vento/Bora > '91 - '96
Old 05-05-2009, 12:52 AM   #1
Blu555fire
Blu555fire Normal reputation
Question 1995 Jetta VR6 won't start.. HELP!!!
I have a 95' Jetta. 2.8L. 150,000 miles. I recently installed a new starter/solenoid, alternator, battery, and ignition switch. It was doing OK until I parked it for about a month and a half. I got back in it to drive and get nothing. No clicks. All my accessories, dash lights, and power windows work. When i turn the key to start the lights slightly dim so i am guessing that the started is getting power to it. Any help is appreciated. Thanx
Blu555fire is offline   Reply With Quote
Old 05-05-2009, 10:53 AM   #2
Franco2112
Franco2112 Normal reputation
Re: 1995 Jetta VR6 won't start.. HELP!!!
Your battery may have enough power for your accessories, but not to crank over your engine. Your battery must have sufficient cranking amps to start the car. I would try a battery change out first, even if the battery is fairly new. Franco
Franco2112 is offline   Reply With Quote
Old 05-06-2009, 05:10 PM   #3
Blu555fire
OK.. I have tried the battery swap and still nothing. Maybe a relay is bad????
Old 05-06-2009, 06:11 PM   #4
Franco2112
Great, you should have plenty of power. Did you go back over the other items that you recently replaced? Ignition switch, starter/solenoid, alternator. A faulty ignition switch could give you this problem or your connection may have come loose. Franco
Old 05-07-2009, 06:56 PM   #5
Blu555fire
Yea my starter is getting power, alternator is good too... i think its a bad connection somewhere.. ill have to get the ignition and all the connections checked out.. Thanx.
Bookmarks
Google
Web AF
