Re: 04 Cavalier rubbing noise
Typically a bad wheel bearing would be described as growling or grinding, not rubbing. I have seen brake rotors that were completely rusted over make a rubbing sound, or a splash shield rubbing on a tire, or something rubbing on a CV shaft. You might have to put the car up on jack stands and have someone "drive" the car while you crawl around under it looking for the noise.
EDIT: After you have it on stands, leave the floor jack (dont use the spare tire jack) under the pinch weld and just contacting it. You want the weight on the jack stands, but you can never be too careful when you're under the car with the wheels in motion. And that remind me, have someone else IN the car while you're doing this, if it slips at all they can hit the brakes. Don't use cruise control!!!
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
When you buy something... a bottle of pop for example, who gets the profit from it and what do they do with it? Maybe your money's going to groups that want to hurt you. I think everyone should do a search for things they purchase regularly "____ supports". Might just find a company you won't buy stuff from anymore.
Reason: More safety stuff
