Hello everyone. I've been quite excited with this kit for several reasons. Firstly, it's a gorgeous car with performance to match. More importantly though, it's because I plan to light it up and also have opening doors and bonnet.
This will be the first time I've done an opening door mod too, so I was quite nervous to start on this kit. Thankfully, this is one of the best kits Tamiya has released which makes life easier.
Started on the engine (Alclad Airframe Aluminium) with simple wiring using nylon "Display Wire". Engine is a lot more silvery and lighter in real life, sorry for the pic quality:
I finally found some (very expensive) 2mm solder and reconstructed the exhaust manifold:
Muffler in Alclad Chrome
Proceded to cut off the doors:
Used styrene to fill in the gap between the body and chassis:
1.2mm drilled into some clear sprue:
Milliput is amazing stuff
It took a few days to try and work out a way to hinge the doors sucessfully so they open without jamming on the bodywork. At first I thought the conventional way was to attach the hinge to the inside of the body. After much swearing and frustration, I found out the hinges worked when attached closer to the chassis so...
1.2mm solder. Even though solder is softer than I'd like, it allows me a small amount of movement and flexibility in building.
I still need to open the hood but after that it will be onto primer and then paint. I'm also hoping I'll have enough CF decal for the whole chassis
Thanks for looking. Please be so kind to leave some C&C's.
