grinding/rubbing noise when breaking 1995 corollaqdsly1 05-03-2009, 10:04 PM i have a 1995 corolla and i recently got sum 17s and switched from kuhmo 185/65-14 to wanli 205/40-17 and every time i begin breaking for a stoplight or stop sign i hear this grinding type noise (sound like rubbing) also acompanied with a wooooooooo type noise but i think that part is just the noise from the tires, and i can feel a slight vibration in my break pedal. Any diagnosis on this or any suggestions or advice ? roadrunner2 05-03-2009, 10:20 PM i have a 1995 corolla and i recently got sum 17s and switched from kuhmo 185/65-14 to wanli 205/40-17 and every time i begin breaking for a stoplight or stop sign i hear this grinding type noise (sound like rubbing) also acompanied with a wooooooooo type noise but i think that part is just the noise from the tires, and i can feel a slight vibration in my break pedal. Any diagnosis on this or any suggestions or advice ? You may have faulty brake pads due to not mating with the rotor when newly installed or a possible worn wheel bearing. qdsly1 05-04-2009, 12:19 AM yes i was thinkin although there is still a good amount of pads left on my break pads maybe simply throwing on a new pair would be a great place to start ? roadrunner2 05-04-2009, 11:16 PM yes i was thinkin although there is still a good amount of pads left on my break pads maybe simply throwing on a new pair would be a great place to start ? That may or may not be the problem. Myself, I'd go to an independent shop for another opinion. A professional one. I do not recommend throwing parts at a problem in hopes of correcting it. That just wastes money. quick69gto 05-05-2009, 06:41 PM Check for a tire rubbing. That's quite the jump in tire size/width. I would bet a tire is rubbing the inner fender panel. Then again, I could be wrong. Automotive Network, Inc., Copyright ©2012
