97 PA driver's side power window
Google
Web AF
Holaday1185
05-03-2009, 02:51 PM
Hey all,
My driver's side power window has been acting up quite a bit lately. The window goes down fine, but when you push the button to get the window to roll back up, it goes super super slow. After about 3/4 of the way up, I have to manually push the window up while, at the same time, pushing the button. About 3 years ago I replaced the motor on this window. Also, I removed the panel today to check for any obstructions and found nothing. Any ideas? Thanks.
HotZ28
05-03-2009, 09:13 PM
:sorry: but you may need to replace the motor again, that is about the only advice we can offer.
Holaday1185
05-06-2009, 06:03 PM
So window motors just don't die? They die slowly??? Slightly confused here. What causes one to "die over time?"
Scrapper
05-07-2009, 12:20 AM
that should run off a cable it could be strecthed or take door panel off see if it's the switch,cable or motor. it may just need lubed.
Holaday1185
05-07-2009, 04:45 PM
I took the panel off the other day and lubed everything that I could get to. Any other ideas?
Holaday1185
06-02-2009, 09:22 PM
Just to recap--- window has been acting better lately. Some days it is reallyyyyyy slow, and other days it's just normal. Any ideas still??
ZiggyPA
06-03-2009, 02:48 AM
Sounds like a bad ground or contact somewhere?
Holaday1185
06-09-2009, 07:12 PM
Hmmm. To be honest, I'm not so sure what I am looking for. Any ideas?
Google
Web AF
