Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Honda > Accord/TSX/Accord Hybrid
Old 05-01-2009, 08:52 PM   #1
dderolph
dderolph Normal reputation
spark plug change interval for expensive plugs
Have a '91 Honda Accord. The last set of spark plugs I installed were http://www.boschautoparts.com/Produc.../Platinum2.htm. They currently sell for $5 ea. at the local Advance Auto Parts store. These plugs have been in the engine for about 40K miles now.
I'm wondering whether these plugs can be expected to last a lot longer than less expensive plugs or whether they should be changed around the interval recommended in the user's manual.
I've noticed a slight roughness in the engine upon start up from a dead stop and when initially starting to accelerate from a gentle cruising. I imagine this could be attributable to various causes.
I recently changed the distributor rotor and the fuel filter. The car has 271K miles on it.
dderolph is offline   Reply With Quote
Old 05-01-2009, 10:23 PM   #2
jeffcoslacker
Lactose the Intolerant
jeffcoslacker's Avatar
jeffcoslacker Normal reputation
Re: spark plug change interval for expensive plugs
Just my .02 cents, but in my experience, Bosch plats suck nard.
Every engine I ever put them in exhibited jittery idle and cold start difficulty.
I had people pay me to pull them out and replace with OEM in the shop.
I'd suggest ND or NGK plugs, and don't use plats if not called for originally. They never seem to improve anything, and sometimes cause minor performance issues.
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
jeffcoslacker is offline   Reply With Quote
Old 05-01-2009, 10:31 PM   #3
jeffcoslacker
Correct OEM-type replacement for yours is non-plat NGK V-power ZFR5F-11
I assumed an LX Accord.
...empty gun rack.
Old 05-01-2009, 11:12 PM   #4
dderolph
Oh really! I'm surprised to hear that. As I said, I've had them in a good while and, except for the recent abnormality (which I can't say for sure yet is due to aging plugs), I did not have jittery idle and cold start difficulty.
OK, thanks for that info. I may visit the local Advance Auto tomorrow and get 4 NGK V-power ZFR5F-11 plugs.
Old 05-02-2009, 12:40 AM   #5
jeffcoslacker
Yeah they work well in newer engines designed to use them, with high degrees of oil control and fuel trim...
But in older and high mile engines and especially carburetor equipped motors they don't seem to tolerate residue fouling as well as conventional plugs.
All the Bosch plats I've seen have a very thin firing tip wire that is recessed. I suspect that's somehow responsible...
Bosch plat tip
NGK Plat tip
I've put a lot of plugs in a lot of motors...overall going with the OEM type plug gives the best results. I always put NGK/ND in Asian cars, AC/Delco in GM, Motorcraft/Autolite in Ford, Champion in Chrysler, etc...
If you really wanna run plats, I'd suggest going with the NGK version for your application...
...empty gun rack.
Old 05-05-2009, 10:49 PM   #6
dderolph
I did get this plug. Now that I've installed the new plugs, replaced the fuel filter and the distributor rotor, the car is running better. I've also noticed an improvement in fuel economy; it's back to what it used to be and what it should be.
Bookmarks
Google
Web AF
