Re: !998 Engine Code P0742
Welcome to AF!
Start by flushing the transmission fluid if it is any color but bright red, if it smells burnt at all, or if it's been more than 30k miles since the last flush. It probably needs a flush anyway (NOT a pan drop, this is worse than leaving the old fluid in there). I don't have access to the code definitions at home (easily, anyway), but I'm guessing the code is for not locking up, since you would have probably said the engine dies coming to stops if it were staying locked. I have seen a flush fix this exact same problem on a Cavalier before. I'm not saying it will fix it for you, but there's a good chance it will.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
When you buy something... a bottle of pop for example, who gets the profit from it and what do they do with it? Maybe your money's going to groups that want to hurt you. I think everyone should do a search for things they purchase regularly "____ supports". Might just find a company you won't buy stuff from anymore.
