Ranger 1994 XL - turn signals don't blink but do come ONdesimunda 04-30-2009, 07:10 PM For some reason when i put the turn signals on the light just stays ON instead on blinking, inside and outside. Any ideas? thanks toddler62 05-01-2009, 08:37 AM I would go to the parts store and ask for a flasher unit that's the most likely culprit, Where its located in the truck I could'nt tell you, have not had to replace mine yet ricebike 05-01-2009, 01:28 PM you can rule out the flasher unit if you turn on your hazard lights as well... i think the flasher unit's the same for both turn signals and hazard lights... did you actually pull out the bulbs and check if one is burnt out? bulb 3156 or 3157 desimunda 05-02-2009, 10:35 AM ok the 4 ways work. so its not the flasher? bulbs all work and have not been replaced lately. The bulb comes ON but doesn't blink with turn signals but does with 4WAYs. ricebike 05-03-2009, 05:19 PM if the flasher unit is the same for both... u ruled it out so bulbs are not burnt/ the wire inside of them are ok when u pulled them off and looked? may be the flasher stalk on your colum then... John Emac 09-08-2009, 01:59 PM Ive seen many a rig with 2 flasher relays - 1 for hazards, 1 for directionals. Theyre usually on the fuse panel. They do sometimes bounce loose, too. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
