Re: Towing with a 2008 T4R V-8 Limited
This may be a late post, but I'd check your owner's manual to see if you need to add some friction modifier additive to the rear differential lube...those with limited-slip diffs tend to call for it. Mechanical locking diffs are different and typically don't need it. Then if needed, see if the lube type you want to use includes this additive. The newest models like yours may not need it, but better to not need it and have it than need it and NOT have it. Have heard bad towing stories of early diff failures due to not including the additive.
I think the Royal Purple brand includes the additive in their formulations. There are others but I don't know them offhand...read the bottle carefully!
Good luck!
Current Garage:
2003 Pontiac Vibe 1.8L AWD
2003 GMC Envoy XL (aka "fat-a$$") - K&N air filter, otherwise stock.
1995 Chevrolet C2500 2wd, 5.7L - K&N air filter, otherwise stock...my weekend hauler.
1992 Toyota Camry LE 2.2L - K&N air filter.
Vehicle History:
2004 4.7L Dakota Quad Cab 4x4
1996 GMC Jimmy 4wd
1992 Chevrolet S10 Ext. Cab 4.3L
1995 Honda ST1100...my first (and only) new vehicle.
1980 Yamaha XS400
1980 Mercury Bobcat...my first car.
