Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Cavalier > Cavalier Problem Diagnosis
Old 04-29-2009, 06:54 AM   #1
Mork
Mork Normal reputation
Opinions on Front End Noise
On my 2004 Cavalier,
I am getting a strange noise in my front end. Mostly when backing out of my driveway and turning the wheels to straighten up on the road. The noise sounds like a "spring" as it boings???? Could it be the strut spring moving in its mount? I have the front end checked out and all is tight including the stabilizer bar but this noise is driving me nuts.
Any suggestions?
Thanks
Jim
Mork is offline   Reply With Quote
Old 04-29-2009, 08:48 PM   #2
J-Ri
J-Ri's Avatar
J-Ri Normal reputation
Re: Opinions on Front End Noise
It is more likely the bearing in the mount binding and the spring pops when it releases, but you're in the right area. From what I hear, mounts are very common on Cavaliers, but I haven't seen it personally.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
When you buy something... a bottle of pop for example, who gets the profit from it and what do they do with it? Maybe your money's going to groups that want to hurt you. I think everyone should do a search for things they purchase regularly "____ supports". Might just find a company you won't buy stuff from anymore.
J-Ri is offline   Reply With Quote
Old 04-29-2009, 10:00 PM   #3
Joe Wilson
Joe Wilson Normal reputation
Smile Re: Opinions on Front End Noise
I've seen it personally...I have a 96 Cavalier that has made that noise for a couple of years now. I've looked into it and had a mechanic look at it and neither of us can find what makes the noise. He thought that a spring might not be completely seated in its mount but said it wasn't dangerous. I installed a new ball joint which it needed but still the noise. It's mostly when I turn right like pulling out of my driveway over a small bump but occurs at other times also. It will almost always happens if you back up, turn right, then go forward. Mechanic said sometimes the A Arm bushings cause the noise, he replaced them, still the noise. I ended up buying another Cavalier. That fixed the noise!
Joe Wilson is offline   Reply With Quote
Old 04-30-2009, 03:44 PM   #4
Classicrocjunkie
Boosted Grocery Getta!!
Classicrocjunkie's Avatar
Classicrocjunkie Normal reputation
Send a message via AIM to Classicrocjunkie
Buy a new strut mount, problem solved.
Just because they look right, doesn't mean they are. The strut mounts on my 04 "looked" fine but they creeked and moaned like SOB's under the same conditions as stated above till I swapped in new ones.
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2004 Pontiac Sunfire Coupe SE Getrag 5 speed
2009 Subaru Impreza WRX 5-door
www.Rdfabs.com
Classicrocjunkie is offline   Reply With Quote
Old 05-07-2009, 09:53 PM   #5
Joe Wilson
I guess I was wrong...the problem wasn't solved. I heard the noise on my newer Cavalier today. How much do the strut mounts cost anyway?
Old 05-07-2009, 10:17 PM   #6
J-Ri
J-Ri's Avatar
Rockauto.com says $42 to $75. Seems a bit high to me though. If you're hoping to do this yourself, you'll need to get "quickstruts" that come fully assembled with mounts,bearings, springs, bump stops, dust boots, and new struts. Otherwise you need a spring compressor and doing it wrong can put you in a coma if you live through it, that said, for possible liability purposes I have no idea how to replace just the mount . We always do quickstruts at the shop, it works out to be about the same price for the customer because they're paying an assembly line worker to assemble them, and they get all new parts. Definately the way to go, especially considering how spings like to break. Not so much on Cavaliers as other cars, but I have seen a couple.
Bookmarks
Google
Web AF
