98 stratus wont start-long list
my daughters car died saturday night. road trip to check on it, no luck so towed it home. 2.5 V6, cranks fine but wont start. you can hear fuel pump whir when you turn key to on. doesnt appear to have spark testing at #2 plug wire, no spark at all. took distributor completely out to check primary and secondary coil, both ohmed to specs. plugs, wires, cap and rotor less than year old and look fine. re-installed dist, used haynes manual to check voltage to and from cam sensor, both good. checked voltage to crank sensor, good, checked FROM crank sensor, should fluctuate between .3-5volts, got a steady half volt or so. changed crank sensor ($65.00!), actually had different resistance readings than old one so i was hopeful, STILL only half volt when cranking according to procedure in manual. read that i should check ASD relay by checking voltage at #1 fuse because it has to pass voltage by there if ASD is good and that has voltage. at a loss, really doesnt seem to be getting spark but other than PCM, i've checked everything else. only thing i cant get is voltage FROM crank sensor, or so it seems anyway. frustrated now so havent put plug wires back on dist after changing/testing crank sensor. what would keep me from getting 5 volts fluctuation on crank sensor wires?
