Originally Posted by cherryelky305
If you cap it, it will build pressure faster. Which isnt a problem unless your filling it up, or sitting in traffic on hot day. The only way to fix it is to replace the hose, or you could put a check valve on it so that it lets the pressure out when it gets to a certain point.
Cherryelky, thanks for the response.I've been mulling this over and I
decided to cap off the three vent ports on tank and venting it
at the fill neck with a vented gas cap.I'll see how well this
works.I thought about connecting some type of relief device
to center hose connector.Maybe I will explore this option.
Thanks, pbernal
