Fuel pump problemlmattiso 04-25-2009, 03:08 PM I just replaced the notorious FSU on my 99 3.2cyl Passport. After I reconnected everything I turned the ignition to ON and checked the gage. It read dead empty and the fuel warning light came on. I started the truck just to see if it would change but nothing. I took the pump out again and checked all my connections. After cleaning off the contacts and reseating them, I put everything back together and turned the key to ON again. Now, the fuel light flashes and the pump won't come on (truck won't start). Did I burn out the old fuel pump?! I've triple checked everything, swapped the fuel pump relay and checked the fuel pump fuse but still nothing. I see 12V on the connector to the pump when the ignition is on but definitely don't hear the pump priming. Any ideas? I think I either burned out the pump or I broke something pressing so hard to get it resealed. Automotive Network, Inc., Copyright ©2012
