94 Wagon disc brake conversion.
belizeboy
04-25-2009, 02:49 PM
I purchased a complete disc brake rear end from a '95 police car, only to find out I should have done more research. Nothing interchanges onto the '94 wagon. Does anyone out there have knowledge of stock GM rear disc brakes that will bolt on to my wagon?
96capricemgr
04-26-2009, 12:01 PM
How would you feel if I told you that stock for stock your wagon dris are BETTER than the stock disc system?? The stock system can be modified to work right but as delivered from GM it did NOT.
I believe the problem with just swapping the hardware over is the wagon has a larger outer bearing, if you can work around that you should be able to make the 9C1 system fit.
I think Kore3 has a conversion kit.
