Tire size, patterndacrew4009 04-24-2009, 09:52 PM 1983 Dodge D150, Slant 6, 4 speed. I need to know what pattern of rim lugs I need. It has 5 lugs, but I see on sites 5X4.75 for example. Meaning? What size would I need? How do I know what rim that has 5 holes would fit mine without trying them on? crazys182003 04-24-2009, 11:16 PM I'm not too sure on your exact model but I do know the second generation dodges (91 and up) are a 5 x 5.5". HEMIDAZE 04-27-2009, 09:47 AM FYI 5 x 4.75 means 5 lugs on a 4-3/4 bolt circle. not easy to measure bolt circle on 5 lugs without some math triangulation. You can "rough it' by measuring from the center of the spindle to the center of a stud and double your measurment. Any place that sells wheels should be able to tell you the bolt circle. ricebike 04-27-2009, 11:06 AM www.tirerack.com 5-114 mm's more specific: http://www.tirerack.com/wheels/tech/techpage.jsp?techid=92 hope that helps you; the internetz good stuff, eh? Automotive Network, Inc., Copyright ©2012
