Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Buick > Park Avenue
Old 04-23-2009, 09:00 AM   #1
dansears
dansears Normal reputation
94 PA Stalls When Slowing Down
My 94 PA will stall out when coming to a stoplight or stopsign. Before hand, if your lucky, you can see the RPMs drop a bit, come back to normal for a few seconds, then they will drop completely and the car dies. I've been told that it is probably the Throttle Position Sensor or the Idle Air Control Sensor. Any thoughts?
dansears is offline   Reply With Quote
Old 04-23-2009, 09:07 AM   #2
maxwedge
A990 racer
maxwedge Normal reputation
Re: 94 PA Stalls When Slowing Down
Welcome to AF .I would start by cleaning the throttle body, removing and cleaning the iac and passages
maxwedge is offline   Reply With Quote
Old 04-23-2009, 09:18 AM   #3
sharpnshine
sharpnshine Normal reputation
Could be the TCC (torque converter clutch)solenoid sticking on. Common GM Problem.
Try this- As your slowing down just before it starts to stall, shift the transmission into "N" Neutral. I the vehicle still stalls then your problem is elsewhere.
It would do good to retreive any current or history DTC's (Diagnostic Trouble Codes) from the vheciles computer to give you a head start on fixing your problem.
sharpnshine is offline   Reply With Quote
Old 04-24-2009, 09:30 PM   #4
dansears
I did what you said on putting it into neutral and it doesn't stall or the rpms doesn't drop.
Bookmarks
Google
Web AF
