Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Ford > Ranger/Courier
Old 04-22-2009, 04:42 PM   #1
teknogeek1300
teknogeek1300 Normal reputation
96', ignition coil failure?
OBD tells me ignition coil B failure, could this be a spark plug? I recently replaced them, no check engine lite for about 2 weeks. Then BAM! Runs fine, seems to anyways.
I have the 2.3L, thanks guys!
teknogeek1300 is offline   Reply With Quote
Old 04-24-2009, 12:27 PM   #2
speedindevil
speedindevil's Avatar
speedindevil Normal reputation
Send a message via AIM to speedindevil Send a message via Yahoo to speedindevil
Re: 96', ignition coil failure?
doesn't that motor have 2 plugs per cylinder? are the plugs on separate coils? if they are, that would explain the coil being bad but still running ok. get an inline spark tester and check them one at a time, preferrably when it's not too bright outside, that'll tell you if the coil is bad, or just the plug. you should be able to get the spark tester at your local parts store for 10 bucks or less, you could also use a timing light to see if they're all firing, just hook it up and make sure it flashes on each wire. Unless this truck has individual coils for each plug, I can't remember, if it does, you'll have to test the plugs with a voltmeter.
"If you have tried to do something and failed, you are vastly better off than if you had tried to do nothing and succeded"-----(someone famous)-----
speedindevil is offline   Reply With Quote
Old 04-25-2009, 01:24 AM   #3
teknogeek1300
Yes, 2 plugs for each cylinder. I will pick one up ASAP and give it a try, thank you!
Old 04-27-2009, 09:26 AM   #4
rhandwor
rhandwor Normal reputation
Ohm the plug wires if you have two per cylinder they should be appx. 1/2 scale.
rhandwor is offline   Reply With Quote
Bookmarks
Google
Web AF
