Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Nonspecific
Old 04-20-2009, 11:10 PM   #1
junior71991
junior71991 Normal reputation
Transmission Interchangeability!!!!!!!
I was wondering? Since the 700R4 turned in to the 4L60 which turned into the 4L60E which turned into the 4L65E, are any of these transmissions interchangeable with each other?? Thanks much.
Ride it like you stole it!
junior71991 is offline   Reply With Quote
Old 04-21-2009, 08:18 AM   #2
MT-2500
AF - Advisor
MT-2500's Avatar
MT-2500 Normal reputation
Re: Transmission Interchangeability!!!!!!!
Yes and no.
Also they now have a 4L70E
The E is for electronic control.
They will still bolt up to a chev 4.3 V6 or V8 engine but.
About the only thing that is the same is bolt pattern transmission to engine.
Inside parts and inside case and converters and valve bodys have changed every few year.
And one for a V6 will have fewer clutches and different converter than a V8.
MT
MT-2500 is offline   Reply With Quote
Old 04-21-2009, 11:24 PM   #3
wafrederick
Banned
wafrederick Has more negative feedback than positive
The book says some will wil not fit and sometimes wrong.You can bolt the 4T65E toto any engine by switching out the final drive and sometimes electrical.Watch out on some on the 4t65E,the neutral safety switch is inside the transmission instead of the outside sometimes which can be switched out sometimes.
wafrederick is offline   Reply With Quote
Old 04-21-2009, 11:43 PM   #4
junior71991
Ok, So I have a 1993 Chevy S-10 Blazer in which the trans needs replaced. Since it has a 4L60E trans in it, what vehicles in what model years am I looking at as a direct replacement trans for my Blazer?
Old 04-22-2009, 02:22 AM   #5
silicon212
AF -Advisor
silicon212's Avatar
silicon212 Normal reputation
Send a message via ICQ to silicon212
I would say '93, '94 are your years. Starting in 1995, the transmission got revised with a PWM control for the TCC, which yours will not have.
You can use a trans for a V8 on yours as long as tailshaft length is the same (and again, uses the same electronics as yours).
And to wafredrick, the 4T65E is a totally different trans, meant for a front wheel drive (transverse mounted) car.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
PC Club is dead. Long live PC Club!
silicon212 is offline   Reply With Quote
Old 04-25-2009, 09:51 PM   #6
junior71991
Ok, So I found a 4L60E transmission out of a '94 Camaro. Would this be a suitable replacement??
Old 04-26-2009, 10:01 AM   #7
MT-2500
AF - Advisor
MT-2500's Avatar
Is yours a 4W drive?
Big differance from a 2W to 4W.
Also wiring and solenoids inside of transmission will need to match.
Always check a salvage yard interchange book for what will fit and what all needs to be changed to get it to work.
Good Luck
MT
Old 04-27-2009, 10:00 PM   #8
junior71991
I have a 1993 Chevrolet S-10 Blazer 4x4 4DR with a 4.3 L V6 and a 4L60E Transmission. I need a replacement transmission. What vehicles and what model years would be a direct replacement for my transmission?
Old 04-28-2009, 10:16 AM   #9
MT-2500
AF - Advisor
MT-2500's Avatar
No one you have tio stay with a 4W transmission.
1993 and maybe 1994 Chevrolet S-10 /Blazer /Jimmy /Bravada/4x4 4WDR with a 4.3 L V6 and a 4L60E Transmission.
But even then you need to confirm the valve body/computer wiring.
Your salvage yard can check there interchange book to be for sure.
Good Luck
MT
Bookmarks
Google
Web AF
