97 malibu overhead cam cover removal- Need help!
After more tinkering and speaking with a GM tech I have an update for those interested.
For the 2.4L motor, to remove the cam covers, you have to remove all the crap on top of the motor to get to the cams. After that you have to remove the timing chain cover and remove the two timing cam gears to get to the last two bolts behind them to pull the cam covers. to make it even more fun, to get that timing chain cover off, you have to raise the car, take off the passenger front wheel, remove the inside fender well, take off all the pulley's to remove the lower bolts on the timing chain cover. Once those two gears are off the covers supposedly “slide” right off. The Chilton’s manual neglected to go into detail on this particular piece of the puzzle.
All that to get the cover off in order to take off the top cam covers to replace a stupid leaky seal. Gotta love the engineering brain power that went into this thing.
Wish me luck.
Reason: Mistitled
