decarbonize?toddmpa 04-20-2009, 01:03 PM Hi. My '01 Rodeo 3.2 V6 loads up after idling for an hour or two. (You have to drive I-95 to recognize this as a problem.) It then suffers erratic idle, modest bucking under acceleration, no CEL, but a white-knuckled wife who wants something done now. I replaced O2 and mass air flow sensors, the EGR valve, spark plugs and air cleaner. (No timing belt yet although it is due at 102k.) The plugs were a lovely tan. The EGR valve was bad. I found the intake manifold gasket problem and had it replaced under warranty. It ran really sweet until I found yet another construction zone in Maryland. I sprayed a can of B-12 down the EGR port, which worked until Saturday, when I got caught behind a one-car flip and roll in Delaware. The dealer wanted to decarbonize it for $180. I declined, suspecting that the service manager wanted me to pay a second time for IMF work they were billing to Isuzu. Afterward I asked the service manager, so your mechanic walked the plenum cover over the parts cleaner, right? No, he said. My questions: Was the dealership right that my problem is gunk on the throttle bodies to a degree that spray cans can't handle? The dealership was pitching a chemical flush applied through the air intake. I've found private garages that will do it for a third of what the dealer wanted. But they say that carbon in the combustion chambers is the usual culprit, and that 99 percent of the time, it is a symptom rather than a disease. (Translation: leave your checkbook on the passenger's seat.) Worth the fight to have it done? Is DIY Sea-Foam or equivalent an alternative? I have searched this site many times as a lurker. My apologies if I have missed earlier answers. Thanks Todd amigo-2k 04-20-2009, 05:18 PM did you clean the EGR tube where is exits behind the throttle body plate? toddmpa 04-20-2009, 05:46 PM If you mean spray down the bigger hole that directs exhaust into the EGR, the answer is no. I am a UW Madison alum. Got Bucky Badger on my rear window. Something of a problem with the JoePa admirers around here. amigo-2k 04-20-2009, 07:53 PM intake after 80K http://isuzufaq.ibctech.ca/inside.pdf Look at the second and third photo for the EGR pipe: http://www.automotiveforums.com/vbulletin/showthread.php?p=1777258#post1777258 Automotive Network, Inc., Copyright ©2012
