Originally Posted by tgraser
I was planning to replace the rear brakes on my 2500HD Duramax diesel today, but found that after removing all lug nuts on the first wheel that I couldn't remove it from the hub. What it the best way to deal with this? a large puller?
Thanks for any help.
when the wheel is stuck to the hub loosen lugs and drive vehicle as mentioned fwd/rev and the wheel will free...do not use hammer or pulling devices..
when installing the wheels remove all corrosion [wire brush] and apply a film of anti seize compound on the mating metal....keep off the lug studs..this will cause you never to have this happen again..
use of this antiseize on the disk/drum bore is also recommended so that these parts remove easy, and do not rust out which can cause them to not mate up properly to the hub flange...
