fuel guage empty to full
dakota1205
04-19-2009, 12:20 PM
I have a 2000 Silverado Z71 with the fuel guage swinging from empty to full and all in between. I have heard of others doing this. I guess maybe its time for a new fuel module. It's been doing this for a couple of years, just keep putting it off. Is it easier to move the bed back or drop the gas tank? Also I have developed hard starting problems here lately, It having too crank extra long before it starts up. Could this be a sign the fuel pump is getting ready to go out. Any info would be greatly appreciated
ukrkoz
04-19-2009, 04:42 PM
could be anything.
read codes 1st.
measure fuel pressure next.
this issue is discussed all over the web. some say, dropping tank is OK. many say, it is much easier to scoot truck bed back, to clear the fuel pump and sending unit.
some say, 5 adults can take bed off completely.
some say, it is cleaning a ground wire on sending unit harness that does it.
pick your poison.
I'd say, should you have that truck bed moved, do as much replacements as you can, while you there.
wafrederick
04-19-2009, 06:39 PM
The sending unit is bad and is a common problem on GMs.
j cAT
04-20-2009, 10:11 AM
my guage does this intermittently since 2000...
if you hit the fuel tank bottom and the guage works,, this is simply a coating of film , that the fuel tank pickup has on it interferring with the current flow...
my plan is to live with this until the fuel pump is replaced...
also use of injector cleaner does reduce the problem ...but no cure..
jyount
04-20-2009, 10:47 PM
He's right. When I worked at the dealer we replaced a ton of fuel level sensors even under warranty for erratic gauges. The were almost always fine, except the fuel varnish or film on the contact strip on fuel sensor. But, they are cheap enough, while there, I would just replace it, I wouldn't chance cleaning it up and putting it back together. If your tank is about empty, drop the tank. If its full, pull the bed. Like said, pulling the bed is not hard at all if you have air tools, and 4 guys can easily set it off. Just put some shop towels at the corners of the bumper between the bed and bumper to protect your paint, and disconnect the filler neck before you get it in the air 1 foot and realise you didn't :) ask how I know.... Same goes for the ground strap between the frame and bed if its got it, if it don't, it is between the fillerneck and frame...
mwid73
04-24-2009, 09:55 AM
PULL THE BED if you change the pump!! The first four times I changed pumps on GM trucks I layed on the floor fighting with the tank and hoses and fuel line connections,etc.....The last one I decided to pull the bed and had no problems what so ever. It's just eight bolts, filler neck, ground strap and tail light harnesses. Very simple, and, it only takes two guys to move the bed off if it's a shorty. I'll never drop another one of these tanks again....
homegrowm311
04-24-2009, 04:15 PM
I agree, lift the bed. When I changed my fuel pump the plan was to use my dad's engine hoist. After we got the bed unbolted, we lifted it up to see how heavy it was and didn't use the engine hoist. It's lighter than we were expecting.
