Re: 1999 jgc Laredo 4.0l tranns problem
Yep; these transmissions are sensitive to low fluid levels...if you've had a leak it's likely low.
Also, where is the leak coming from? If it's from the transmission pan, that gasket is an easy repair -- AND if it's never been opened up before, this is a great opportunity to replace the trans filter and some of the fluid (about 1/2 is in the pan).
Fresh fluid can work wonders if you're having a shifting problem. I know a guy who was told he needed a rebuild, he changed the fluid every month or so when he had a shifting problem, just a pan drop and refill each time, and the problem went away for another 100k miles.
AF's RULES can be found HERE -- Please read them.
