Re: check engine light VS. clock?
The two events should not be related. The clock has nothing to do with the engine's operation, sensors, or emissions. It only serves as a constant reminder that you're late for something. The clock in my Cam will fade in & out as well, so it may be a simple wiring issue.
The check engine light usually lights up immediately when a problem is detected but can also be lit on some systems based on what's called "two-trip detection logic", meaning that if the same issue is detected during two successive engine starts/operations, the code will be stored and the CEL will light up. When the problem being detected is no longer present or doesn't meet the two-trip detection requirement, the light will go out but the code may still be stored in the computer memory. Many auto parts stores will read your codes for free using a code scanner...check it out for any stored codes and have them cleared from memory.
The most likely reason for the CEL coming on is a missing, loose or faulty gas cap. But also check your gauges for any out-of-normal readings, especially oil pressure, engine temperature, and voltage...not necessarily in the RED, but a reading that isn't where it usually should be. That is a sign of some larger impending problem. Have the wife keep a closer eye on the gauges to see if anything creeps up. Hope this helps!
Current Garage:
2003 Pontiac Vibe 1.8L AWD
2003 GMC Envoy XL (aka "fat-a$$") - K&N air filter, otherwise stock.
1995 Chevrolet C2500 2wd, 5.7L - K&N air filter, otherwise stock...my weekend hauler.
1992 Toyota Camry LE 2.2L - K&N air filter.
Vehicle History:
2004 4.7L Dakota Quad Cab 4x4
1996 GMC Jimmy 4wd
1992 Chevrolet S10 Ext. Cab 4.3L
1995 Honda ST1100...my first (and only) new vehicle.
1980 Yamaha XS400
1980 Mercury Bobcat...my first car.
